As rework continued today, one of the experiences I found when I removed the power boards, was that each of the pairings of finals in both the channel outputs and the voltage regulation circuit, were different lots and most disturbing, the rank. The outputs on the left were a rank of P and the right was Y, and the voltage pairs were one side 2SC2773/2SA1169 and the other 2SC2922/2SA1216, both of greatly different rank. B&D was kind enough to match 2 pairs of 2SC2922/2SA1216 Y's to match the one side, which leaves me with a matched set of 8 2SC2773/2SA1169 in both lot and rank to match outputs on both R&L sides after rework. I can only conclude that either no one was paying attention at the factory, or, this unit went through repair and the tech saddled them like that.
As a sidebar, I get asked at times, how tight do you place the screws, (and yes there is a torque spec) and for the MT-200 it is 7 inch-pounds. Anything over 10~12 inch-pounds yields diminishing returns, and will distort the package. SanKen recommends Dow SC-102 compound for use with these devices.
