I am a new member who joined to because my old mc225 died and I decided to fix it myself. I am a genetic engineer so am comfortable with technology but have no electronics training.
The sudden death of my mc225 turned out to be a shorted output transformer--it is now being rewound by doc Hoyer. While the unit was open, I decided to perform a thorough restore as I learned reading posts: power supply caps, bias rectifier replace, bumblebee caps replace. Also checked resistors and about 25% were off spec so I decided to just replace them all.
My question is about the voltage specifications. Measurements at the tube pins are all within 10% except for the low voltages on what I think is the cathode for the 12ax7 and the 7591 tubes. They measure 20% high (1.2v, spec 1v) and 50% high (1.2v, spec 0.8v) respectively. While not stated in the mc225 service manual, other McIntosh manuals state a 10% voltage tolerance. So, are voltages within 10% good enough and are the high cathode voltages a worry?
Thanks in advance for any insights you can provide.
