dogwan
Dogwan
I just re-foamed a PC60/PC50 set and took lots of pics and foam measurements. This will take several posts to get it all in, so bear with me.
Hey all,
I recently picked up a very nice matching set of PC-60's satellites and a PC-50 sub. All in need of foam replacements. Originally advertised as PC60's only, when I showed up the seller said his dad had just dropped off the PC50 sub so I was pleasantly surprised. The satellites were advertised as one of them having dropped in volume (a sure sign of a failed tweeter), but the woofer surrounds were still intact ('ish). The subwoofer surround was already failed. However, the casework and grills were in great shape. Only one of the sat's had some water spotting, but no swelling or other veneer damage.
Sure enough, when I got them home I found one of the tweeters dead. I managed to pull that tweeter and disassemble the diaphragm from the magnet structure and found the joint between one end of the VC magnet wire and the tinsel lead had failed. I was able to just get it soldered back together and the tweeter re-assembled. So, all drivers worked. Even the Subwoofer (played gently in a vertical position).
Note: jumping ahead to after the successful re-foam of all drivers, the other tweeter failed in exactly the same fashion (tinsel/magnet wire joint). So I repaired that one as well. However, I figured at this point both tweeters are compromised (if playing), so I ordered 2 new ones from Phase Tech and they should be here around the end of the week.
Here's a pic of the Tweeter (part no. T-636) diaphragm and the suspect joint.
Here's pics of the cabinets of the PC60's
Sorry, no pic of PC50 case, but it is excellent. When the weather gets warmer I am going to refinish them all and will post pics then.
Hey all,
