So, this PL50 basically works, auto return most of the time. I worked on it 20 years ago but didn't know enough and wasn't happy with the outcome. It's time to look at it again. First off, the damping fluid I put in as leaked and was up in the auto return mech. I disassembled it and cleaned it good. Now for the lube part of the auto return mech. No lube on the Stopper #28 it stays clean and dry. I'm thinking on some super lube on the shaft of #66 and under #14 . #65 #26, #9 are Teflon washers so no lube. What do you think? There is very little contact surface at #16. I need to make the rotor cap #68 leak proof: I'm going to use 300k cst. for damping fluid. The cam lever #52 has been notched out on this PL50 which I think makes the Stopper#28 swing out further to get bumped by the platter pin, more on this later. Any thoughts or suggestions?
