It isn't really a Rowe any more as it will be 6L6GB or earlier. I will also be using IBBA and EFB boards. I have the audio circuits nearly complete except for installing the PC boards. The transformers will be about the last things to install just to keep the weight down while I do the other wiring. Have made decent progress so far. Not sure how the transformers will work out. I also added some Cinch barrier blocks for the secondary connections and wiring to the binding posts which I installed where the 70V terminals were originally. I patched/filled quite a few openings that I don't need. Had to glue in some thin aluminum under the larger holes so the epoxy and bondo had some support. Trying to make a bit of progress each day but not sure how soon I will be ready for power up.
I am also altering the 12AX7 circuits a bit per Dave Gillespie's Fisher 400 mods.
