Another SA-100 Clone Build
tekuhn
AK Subscriber
I'm a big fan of @dcgillespie and his outstanding and well-sorted designs. I wanted to build a stereo amp using P-P EL84's, and figured building one of his Fisher SA-100 clone amps would be about as good as it gets. I had no trouble finding the Stancor AA-100 output transformers and settled on a new Weber replacement PT of suitable specs. My B+ will likely be a little bit lower than specified, but should be close as I have chosen a plenty beefy PT and choke and will be using solid-state rectification. I made some modifications by adding individually adjustable bias for each power tube. Also, since my PT has a bias tap, I'm using conventional negative grid bias and that form of EFB™. I really like symmetry in the physical layout, and tried to arrange the components accordingly. My preference would have been the right and left channels on opposite sides of the chassis with the power supply in the center, but unfortunately, with the two channels sharing half the AF and inverter tubes I didn't think it wise to arrange those two tubes in the center of the chassis due to the long wiring runs needed to each sides power sections. I prefer to paint my chassis' to prevent rust or corrosion. I considered using a Fisher-inspired burgundy, but ultimately settled on a light champagne gold metallic color.
The mechanical build is nearly complete so I thought I'd go ahead and start a build thread to share the project.
Many thanks to @dcgillespie for his expertise and willingness to teach and share. I have learned much from his posts......
I am delighted to see your project, especially the layout choices, power transformer, EFB driven from the bias tap, etc., and will watch it carefully. Very nice work so far! Best wishes with you project. Thanks for the nice schematics you are drawing as part of your documentation. I’m sure I will see things that I will want to ask you about.
In the next few weeks I will also start another SA-100 clone project where I have made similar choices, with the exception of the orientation of the EL84 tubes, with each pair going front to back in front of each output transformer, with the 12ax7 and 6CG7 between them. I plan to use a Heathkit AA-100 PT, also with SS rectification. My choke will not be quite a large, but I plan to beef up die capacitor after the choke to 220uf/550Vdc. I’m using higher voltage capacitors in the PS to handle the expected voltage surge before the power tubes start conducting.
