HH-Bham
Well-Known Member
Should I replace the snubber on my 2252 with a new part that came with my power switch?
I've been cleaning up a 2252 that I came across and just replaced the power switch. Power was always on, and as it turns out, a hack job had been done and switch had just been disconnected and wires soldered together. I bought this power switch off ebay and have installed it -- working fine. The switch came with an "arc suppression cap" and listing says:
"When replacing a power switch always replace the old arc suppression capacitor. Most arc suppression caps are located across the power switch terminals however some models have this cap mounted across the switched AC receptacle on the rear panel."
The original snubber is labeled ".1uF + 120" ohm, which is consistent with my research here, and schematic which shows cap and resistor.
New "arc suppression cap" is labeled ".33pF 275V" and as far as I can tell no mention of resistors. It does have X2 designation. Pictures of new part (posed on heat sinks for convenience and lighting) are attached.
Keep original? Replace with this new part? Replace with different part? (Edit to add: I've seen the other thread. Just doesn't seem the "new" part that came with my new switch is right and also wondering about the need to replace the original snubber.)
Thanks for any advice. This is my first post on this Marantz forum. Now that I've read the excellent service manual and been inside the unit, I'm a big Marantz fan -- quality unit. Looking forward to giving it a good listen tomorrow.
