mboxler
Well-Known Member
Although this is for my own benefit, I thought others might be interested. Any suggestions ae welcome. All measurements are with the horn mounted in a La Scala and the microphone a foot away from the mouth. All drivers are connected straight to the amplifier.
First is the K55V solder lug mounted on a K400.
SPL & Phase
I believe the bump in SPL around 4200hz is the result of the dual phase plug design.
Distortion.
I limited the plots to 2nd and 3rd Order distortion to keep it cleaner.
If I'm doing this right, that's a lot of distortion beginning around 4200hz. Coincidence? Tempted to measure a K55V Push Pin to verify.
I designed the 4500x to eliminate any squawker distortion after 4500hz and let the newer tweeters take over at that point. This is the first time I actually plotted the distortion I aimed to eliminate.
SPL & Phase
Distortion.
