omishra,
I like the flooded ground plane. I hadn't seen that for a while and it makes sense. The routing of components becomes more open and the signal path more compact because of it.
Looking at the schematic, I wonder if R1 and R2 are necessary. The input draws no (negligible, pA) current. The effect of these is questionable.
So is there another board order going on? Just a little confusing now, sorry!
Sachin has some for sale last time I checked for AK's that want one.
I think Omishra designed a slightly different laid out board than the ones Sachin and Hypno produced.
Great work Omishra and welcome to AK.
Fasterdamnit aka Jim is responsible for kicking this thing off, I just came in on the end and Sachu888 has been kind enough to get more PCB's made and distributed to AK'ers.
Many others on here have given valuable input as well.
It's just good AudioKARMA all around. :thmbsp:
Now this PCB is neither available nor given for fabrication. But I am planning to do so. It will take 2-3 weeks to get in hands.
I am planning to make 10-15 boards. So thought of getting this layout verified by all of you. I talked to Sachin and thought of publishing this layout before getting money spent over it.
I will give you one and parts if you calibrate my 482Z.![]()
Omishra: How much effort would be required to mod the PCB layout to add tracks for HT's Simple Preamp? The mfg cost would go up because of board size, etc. Output RCAs could be connected between the CNC and the SP for those who only want the Phono Preamp.
What say you all??? Anyone else interested?
Can you please point me out exact schematic/diagram which you are referring? Do you want that preamp as separate PCB or same CNC PCB to be extended for third OPAMP of simple preamp?
^^ Thanks Sachin. I think the last post has latest design. It could be done but I am not sure how many takers are there? Otherwise if added to existing CNC PCB then these part of the board can be kept unpopulated for only CNC use.
It could be done but I am not sure how many takers are there? Otherwise if added to existing CNC PCB then that part of the board can be kept unpopulated for only CNC use.
