Omishra,
Nice board.
How about having the inputs and output
connections on the same side?
It is easier to use that kind of layout where the connectors
are located at the back, like the enclosure used by Sachu888.
Case 1: Input - output, signal level changes drastically ( more than 10X of input)
Case 2: Input - output, signal level remains more or less same between 1X -10X range of input. (e.g. equalizer, filter etc)
For case 1, I always felt safe when input and output are away from each other if they are different (here signal level). I fear for feedback ( my radio background).
I would like to use your suggestion for case 2 above. This is my personal feeling.
I usually put the inputs to the selector, then to the span of the level pot and from there the pot wiper to signal in and return to common. Otherwise the elegance of your board layout is quite admirable.
Thanks! I would be happy to remove extra pads and traces. It will reduce another half inch from dimension. I will do that to keep only L (+, -) and R(+, -).
Let us hear what others say?
CNC + Super Simple Preamp:
dodog (2 CNC + 2 SSP)
sachu888 (1 CNC + 1 SSP)
omishra (1 CNC + 1 SSP)
pauze (1 CNC + 1 SSP)
bobrown14 (1 CNC + 1 SSP)
learn2tt (1 CNC + 1 SSP)
Grainger49 (1 CNC + 1 SSP)
ghazzer (1 CNC + 1 SSP) <- please confirm.
HypnoToad ( 2 SSP)
If something is incorrect then please update.
