Another SX-1010 Needs Help - Power Issue
12344321
Another 1010 out of the closet for repair... yes I have several stored away that need help. This one came out of the closet with a fully broken power board- oh joy! Luckily I have an aftermatket one from rcs16 that was previously used successfully
Step 1, I connected the board to pins 1-7, and 12 to check power. No other load connected. 100W DBT fully lights. Checking voltages, I have positive and negative, but everything is very very low... I'd have to re-check but I was seeing like 20V and -20V where I should see 56 from power supply. Only saw a few mVs to the main rectifier from pins 1/2.
I removed ALL fuses from the unregulated supply- bulb is a touch less lit but basically still full lit.
I removed the two red (primary?) Transformer wires from pins 1 and 2 and unit does absolutely nothing... seems like I should see power from other posts? I checked the ressistance and it was pretty high from what I recall so I don't think there's a short there.
Right now I am suspecting a transformer failure since it seems like the power to the unregulated is extremly low to what it should be. How do I check it more thoroughly? Am I right in checking across the stages, like red to red, blue to blue? Is there a nominal power rating I should see into the power supply?
If not the transformer all I have left are filters (test okay on esr 70 gold, 16500uf/17870uf 1.3 and 0.7 esr) and rectifiers which I'm not sure how to test ones that size.
Unit does have the 6A dummy fuse intact still. Both amps are offline, no outputs, resistors added to 10/13/19 fornfeedback. Figured I'd ask for assistance here before condemning the xformer.
Probably have a shorted output(s).
You could check them where they are wrapped to the amp boards. Look for continuity (0.50 ohms) across all three output leads on those amp pins. Any continuity below 1 ohm is shorted.
No outputs are unstalled, and the wires to power them are not connected. I knew the unit had major issues already. Someone else has done an amp rebuild on it before I got it. Ill be fully rebuilding the amps with proper parts before trying to run audio- for now its power related problem.
Right now I am suspecting a transformer failure since it seems like the power to the unregulated is extremely low to what it should be
It will be if you are using the DBT and its drawing too much current. To verify, check the ACV across the transformer primary?
disconnect (unsolder/pull square pins) the +red (#16) and -orange wire(#15) on the AWR-053 running to the big ecaps to isolate them from the rectifiers.
test with dbt again, if lamp dims down then you can apply full AC and then check AWR-054 for correct voltages.
check 18mF/63V ecaps wired backwards? Are they original?
+/-54V unregulated from AWR-053 & ecaps goes to each amp module too (for the drivers), so could be shorted bjts on one or both of them
Look at the schematic to figure out where everything goes.
Methods of elimination.
I’ve had a couple of filters on the 1010 shorted.
If you’re going to rebuild it you could unwrap those connections on the big filters and see?
With the wires off pins 1 & 2 on the AWR-053 pull all the fuses on the AWR-053 (F1 through F6) and power it up on the dim bulb and see if it is still bright.
With those wires off and the fuses removed there will be no load on the secondaries.
If the bulb dims then you can check for AC voltages at pins 3 through 8 referenced to ground. And red to red on the wires removed from pins 1 & 2.
If the bulb does not dim then the problem is in the primary side of the circuit.
Quick check of the primary. Unplugged from the wall and with the power switch on measure the resistance across the prongs of the plug.
To clarify. When I remove those wires I should see absolutely nothing happen correct? No bulb activty, no receiver lights, anything? Cause that's what happens when I remove 1+2 or 15+16. Does probe orientation matter when measuring? Yes the filters are originals.
Yes this is the next step. Filters are original, luckily I have a drawer full of exact same filters that work I can use in a pinch if I have to.
Okay so with no fuses installed, wires 1/2 and 15/16 intact = bright bulb. If I remove eother of those wire sets = no bulb light at all, no receiver lights. Normal?
Not Normal! Bright bulb indicates a large current draw.
Removing the wires from pins 1 & 2 disconnects that part of the transformer secondary from the power supply. Having a dim bulb in this condition says to me the transformer
is not the problem.
With 1 & 2 connected and 15 & 16 removed having a dim bulb tells us the rectifier is not shorted.
That leaves us with something down stream of pins 15 & 16. And since I believe you said the output power transistors are removed that pretty much leaves us with a shorted filter cap or caps or the wiring after the caps. I would suspect the caps first.
Discharge the filter caps and ohm check across them.
FYI disconnecting the wires at pins 1 & 2 or 15 &16 should not have any effect on having or not having receiver lights, however if Fuse F1 is out you will not have lights.
is not the problem.
Okay that is helpful, is where I was leaning towards.
Last night I disconnected both filters. There's 1 that might be bad... it was reading kind of all over the place in the peak meter and via de-5000 (which I am still learning how to use.) It was measuring between 15,800 uF and 17,650 uF. ESR varies from 0.78 up to nearly 2 ohms. The other filter seemed atable, 18,000-19,000 uF and right at 0.38-0.60 esr.
Sadly I dont have any good 18k filter pulls on hand, I have a bunch of 22ks that are too big to fit, and a pair of 50V 20ks. Ill have to pick some up when I can but not sure that's my issue.
Just to be clear, it is my understanding that with the wires connected at pins 1 & 2 and the wires at 15 & 16 disconnected you get a dim bulb at power on, correct?
It is also my understanding that with the sires connected to pins 1 & 2 and 15 & 16 yo get a bright bulb at power on, correct
And it is my understanding that the output transistors are not installed, correct?
If that is all true then the high current draw (short) is downstream of the PS board. With the output transistors removed it leaves the filter caps, the wiring/amp PC board, or possibly the driver transistors.
I am suspicious of the weird measuring cap. Put your ohm meter across it and see what it does.
Yes that is all correct with the unit in regards to bulb conditions.
I measured the filter, it started off at 0 and then steadily creeped up to around 2.2k then slowly continued from there. The other filter behaved basically the exact same way. Check wiring? I may have an idea to what it could be
Using the chassis as the ground side ohm check from pin 8 or 9 and pin 11 or 12 of one of the power amp boards.
Following along since I have a 1010 project on the go also.. From your test sounds like filter caps may be leaky (electrically). I would try EastPoint's suggestion.
I think I get what you mean... with black probe to chassis, I went to 8, 9, 11, and 12 both channels. Some interesting results.
Right:
8- 1.909
9 - 1.909
11/12- 0L
Left:
8- 1.369
9- 1.370
11/12- 0L
Seems to be an imbalance there, granted the left channel was creeping up a lot slower and that's where it seemed to settle at. Points to bad semis?
If you have a filter cap with the right specs that’s too big you can hook it up with alligator clips temporarily. Just make sure you get polarity right.
I like it! I'll work on that tomorrow/Saturday.
Okay bit of an update, I updated the wiring for filters to spade crimps and connected them to a pair of 22k/80V mains I had pulled from a 1250. Verified all my connections were good... powered on... and I think if the relay could have clicked it would have! Bulb dimmed to about halfway. Very good! To me this confirms I need some filters... Ill likely use what I put in my other unit, so will get that ordered ASAP.
Still a bit miffed I cannot get the unit out of protection. I connected pins 9 and 13 since it powers the protection circuit/relay. Didn't click, so I measured pins 1 and 3 pn protection board. Had 700+mV right channel and 23V left channel. Guess it's amp rebuild time.
Yeah with 23 volts on the left channel input it is not coming out of protection. 700mV is probably close to or over the threshold for the right as well.
you mentioned earlier output transistors were removed, were some of them shorted?
Nope. I have yet to find a single part shorted or remotely out of spec in any form that I can detect.
I repopulated all the semis on both channels, including drivers. Bulb now goes completely dim. Initially I was still seeing 1.5V on both pins 1 & 3 on protection, but it occured to me I didn't have the negative rail powering the amps. So I reattached all the wires, powered up on DBT.... no relay, but DC offset is tentatively set to ~10mV per channel, and I was seeing 400mv or less on pins 10 and 13 on amp to ground. So for all intents and purposes, minus the outputs, the amps appear to be functional and responding to DC offset adjustments.
So I guess now all that's left in this saga is why the relay isn't clicking. I will complete the rebuild on the protection board and hopefully that 945 is the issue. I have already recapped it, replaced the C1384 with 2690, as well as two other C codes (I forget off hand) with 2383s, and added the flyback diode across pins 9 & 10. I'll make sure the relay is getting power, if it is, then I'll be adding a relay to my shopping list.
In case anyone was interested in my amp rebuild:
Q1, 2, 3 - KSA992
Q4- KSA1381
Q5, 6- KSC3503
Q7- Toshiba TTC004B
Q8- " TTA004B
Q9- TIP47
Q10- MJ5731
Q11- KSC1845
Q12- KSA992
** NOTE: Q9/10 is my personal choice for drivers due to testing on various other units, for me they are the most stable and sound the best when used with modern outputs. But you can just as easily use more available drivers such as KSA940/KSC2073 or MJ15032/33. I have used them all successfully **
