Antenna coax connection
dgta
I'm embarrassed to ask, but will anyway :)
I just realized I have a Yamaha receiver that has an FM antenna coax jack that is NOT an F type and will not take an F type connector.
What are these connectors called? And will a standard cheap (push-on) 75 to 300 ohm balun fit it?
For FM, should be a male "IEC 169-2" connector. You need a female to put on the end of your cable. Balums come in both male & female form, so you'd need to make sure you get the female variant.
That's a European RF connector, correctly identified by steerpike2, and it's known for causing reflections in the cable due to poor impedance match. If I didn't care too much about preserving original appearances, I would replace that thing with a standard 'F' type female connector. ...Assuming that you're in North America.
OK, thanks, in that case I will look to see if it's easier to replace the jack with a standard F type.
