Copa1934
My ears are bleeding
Ok, so posts have been "...port the good drivers to a larger cabinet..." "...extend the back/front of the cabinet...." "...add a port to the cabinet..." and on and on. Obviously many of these ideas, and more, are sensible and practical, etc., however there are people, myself including wondering "are there less conspicuous ways of doing this?
Many of the mods, obviously, are for improvements like extending bass response, knowing of course there may be adverse affects.
So, have any of the following mods ever been approached and how successful were they?
1. Add volume by way of the speaker terminal opening. Remove terminals, extend into outboard enclosure, relocating terminals into outboard enclosure. Since the enclosure will in a sense be hidden (from front view) and the enclosure and be modified at length for volume with no impact on the "main" enclosure AND no extensive mods may be required of the terminal opening, seems like a viable option to retain original box?
2. Knock holes in base of cabinet, mount onto additional volume made to look/appear like a speaker stand using PVC or other pipe material to join enclosures. The massive mod would be limited to just the base of the cabinet and can be reversed (if one chose to do so).
Again, these mods are meant for someone who might want to keep the original cabinets, for whatever reason, but not subject too many visible mods.
