That's definitely either a DH3 or a DH2010 (effectively the same thing, the so-called "witch hat" driver).
There's no reason you couldn't make an outstanding speaker with an EVM18B, a SP12B and a HT9040/DH3.
I'd probably use the 18B at about 125Hz and down, and the SP12B from about 125Hz to 1500Hz or so.
You could probably actually start with an E-Wave crossover (the greater-than-95dB version), for the mid-high crossover, and just add a crossover on the low out of the E-wave crossover to separate the 12" from the 18". A 20mH choke and 80uf cap, in both the lowpass and highpass parts, could work fine. I'd suspect that the sensitivity of the 18" and 12" would be pretty close- you might have to put a slight L-pad on the 12", if there's too much midrange compared to bass- then just adjust the L-pad on the E-wave crossover to blend in the horn...
Put the SP12B in about 2 cubic feet sealed, with the enclosure completely filled with fiberglass insulation.
The 18B needs a big box- optimally 12 cubic feet. Incorporating the 2 cubic feet for the midrange, into the enclosure volume, and building it out of commonly available 3/4" thick plywood- that would wind up being about a 2 foot by 2 foot by 4 foot enclosure, outside dimensions. You could reshape that, but the total internal volume would need to be between 13 and 14 cubic feet, all combined...
That speaker could easily be driven by 15 watts per channel. Easily a 98dB/1w sensitivity, or close.
Regards,
Gordon.
