Vintage TX
Analog forever
I have been remodeling the shop the last month here, and also a bigger AC-unit.
Realized now I need more outlets and checking the circuit-box it's full....
Shop has (1) 15 amp breaker and is 1300 watts.
If I run the AC 12.000 BTU (115 volt, 7,6 amp) with 14 gauge wire to the breakerbox and turn the security lights on in the front-yard..the breaker trip directly..
So I checked the box for adding a seperate circuit.. none left.
I also upgraded the lights inside with fluorescent light with a total of 240 watt.
That is not included all the other outlets I want to use with testing, music listening, soldering etc.
Was thinking adding a small fridge but seems a side-panel has to be added to the first one...
Any ideas what to buy and how to do this the right way.
Before I had a big 220 unit AC/Heat but that monster was hooked up on a seperate line and pulled more $ $ then the house..
I changed that line to my compressor instead also 220 volt.
Also the main panel with meter is outside and the only panel is inside the house.
Any ideas ?
Any ideas ?
