I’m trying to rescue a pair that I picked in a pile of junk, so they were pretty rough.
I’ve finally got to the point of putting all the drivers back in, and they sound bizarrely lacking in deep bass.
For anyone interested, these are a three way speaker. 12 inch woofer (heppner I think) 5 inch mid (heppner) and a phenolic ring tweeter.
The tweets I replaced with one of the reissues that you can find in various places. I only had one good original, but can compare, and in someways the copies are better...not so bright and little “paper coney” sounding, but more smooth and higher extension.
The Mid’s I got on the auction site from someone who said they were pulled from DLK 2s. But they have much smaller magnets. They are also heppner drivers and drop right in (the basket has more of a square shape, but holes and cutout are fine. )
Again I only have one original, but at least I can compare. They sound different largely in the same way as the tweets, more paper cone sound, but much smoother and less harsh.
The issue comes down to the woofers. They just seem to have a high fundamental resonance, so they are push towards 120 to about 250 hz, there are some deeper lows, but they are relatively attenuated.
The result is, especially with the newer drivers, is very midrange heavy. It sounds like the woofers are overlapping, like all the drivers are overlapping a bit, resulting in a very dull, boxy sound. The old drivers lessen this a bit, but I feel like the issue is the woofers.
I did try switching polarity in the Mid’s, and I’m sure I have it right.
The 12 inch woofers have an accordion style surround, treated cloth or something. And the are very stiff, with much less driver excursion than I’m used to with foam or rubber surround. They are original, they actually have the DLK logo on dust cap.
But pushing in the drivers, they feel very stiff, almost like guitar amp speakers.
The other changes are I recapped, and replace the original electrolytics on tweeter and mid with Dayton film caps, and the woofer with a new non-polarized cap.
The originals had some kind of loose cellulose filling which was gross and deteriorated. I replaced with polyfill didn’t cram it full, but a modest amount.
The cabinet has a port, and after first listen I went back to make sure the filling wasn’t blocking the port.
Anyhow, it blew my mind that a very heavy cabinet with a 12” woofer and a port tube would render such wimpy bass.
I’m now left pondering that age old question “is this how they are supposed to sound?”
There could be various elements but from what can hear the 12 inch woofer just doesn’t generate much deep bass. I wonder if the doping on the surrounds might have stiffened up.
Overall, not a bad sounding speaker, but the voicing is off.
Thanks for reading, if any has any comments I’m all ears
