Hey guys,
Not saying that I won't take up the challenge of going through my X-100-2 but before I post a detailed thread about my amp, I was wondering if there were any Fisher experts in the Seattle/Tacoma area? I'm relatively new to tube amps but learned a lot recapping, modifying and adjusting bias on my Scott LK72 a few weeks ago. I would like to try and do the same for the Fisher but I'm finding that the X-100-2, at least, doesn't quite have the documentation available. Nor does it have the number of threads and info about others who have worked on them.
The unit is fully operational save a couple switches that need to be cleaned. I believe one of the inputs might be noisy but can't remember which one? But I've been using it for a good 10 years now. After going through the Scott and getting it set up, I was amazed at the difference in sound a properly adjusted amp could provide. I'd rather not listen to the Fisher too much until I go through it the same way, although even as it sits right now, it still sounds pretty amazing.
I removed the bottom cover today because I noticed the inrush current was immediate when turning on the unit. My Kill-a-Watt showed just over an amp at first power on then dropped to about 400 milliamps and slowly rose to about 900 mA during operation. I wanted to install a CL-80 at the least just to stop that initial current surge during warm up but I wasn't sure where I should install it. On the Scott I just put it inline with one of the AC wires going to the power switch but the Fisher's switch has a metal housing and insulator tube. It was just a precursory glance to familiarize myself with the unit. When I saw that someone had already hacked up one of the electrolytics and wired it a certain way, I guess my confidence took a little hit because now I was going to have to reverse engineer someone's repair. From what I can tell, looks like someone already went through and replaced the output coupling caps but there still may be some oldies that need replacing. What about that black and yellow one in the power supply question? And what do you suppose is underneath the black heatshrink on those two components connected to the electrolytics?
Just thought I'd get the opinions of those much more experienced than I so I can get some idea of direction to get this wonderful little amp in tip top shape. Thanks in advance for any comments or suggestions.
-Steve
-Steve
