Yes indeed they work well. I’ve built three of them and they’re great. Ignore the through hole resistors, I was out of the SMD parts and just haven’t fixed it as I haven’t needed another yet.
I ordered special boards as they’re the thicker aluminum substrate available for heat sinking purposes. Others have had success with regular FR4, but one of mine was attached to the rear panel of the amp for heat sinking and so I thought I should get the aluminum to help in that.
I would definitely go this route over buying one and hoping that it is authentic. This board built with discrete components is going to be superior to the original anyway. If you’d like to go this route I’m sure it would be much less expensive to have someone with the parts make you one (me or anyone willing to offer) than it would be to order up a set of boards and all the parts individually if you only need one or two.
Dan
