FWIW, Sencore have always used very good quality parts, and very good design engineering in their US manufactured test equipment over the many, many decades they`ve been in business.
My (2) PA 81s (one for each bench are ~30 yrs. old and function properly within their specifications every time I power them up.
Unless the OP`s PA 81 has somehow (hard to do, due to thermal overload protection, and DC presence on the load disconnection protection) been abused !
I really can`t see any reason for concern(s) about the reliability and the unit failing factory spec/performance.
Replace all the handful of electrolytic capacitors, if concerned, for ongoing, and future confidence.
I have the greatest confidence in all my Sencore test equipment, or I wouldn`t have started purchasing any of their expensive brand new gear in the late eighties when my repair business started taking off, and have been time saving for all my audio repair needs.
However, I felt the need to do a easily done, & undone simple modification to both to better suit testing tube amplifiers by non invasively installing a mini switch to disconnect the unit`s DC presence protection circuit`s disconnect relay`s coil when testing tube amps so a very low frequency noise/pulse from the tube amp wouldn`t trigger the protection circuit thus removing the load resistor while the amp was being driven ! Not a good thing to do !
