Any of these any good?
x_25
Big Vandies!! Mwahahah...
There is a guy selling these for $50 per set. Any of them worth it?
Linear Suspension - Model 44-2B
12" Base; 6" Midrange; 3" Super Tweeter
Cabinet dimensions: 14" W; 12" D; 24" H
Cloth Grill
Sansui - Model SP-1500
12" Woofer; 5" & 6.5" Squawkers; 2 X 2" Tweeters
Cabinet dimensions: 15"W; 12" D; 26" H
Wood Grill
ADC - Model 12
Three way
Cabinet dimensions: 14 1/2" W; 11" D; 26" H
Cloth Grill
Sansui - Model SP-30
6.5" Woofer; Horn Tweeter
Cabinet dimensions: 10 1/2" W; 8" D; 17" H
Wood Grill
I'd agree with the advice to pass. Are you looking for something in particular?
For myself, not really. Although my friend wants to do a concert with our band in his garage and we only have a 100wpc amp to do it with so I am keeping my eye open for some cheep efficient speakers.
If you're running live sound through them, you don't want home stereo speakers- different animals. Same would go for most amps, too, is the 100WPC amp you refer to a receiver?
je
je
Yeah, 100wpc receiver. It really doesn't matter for the sound quality, it is going to be a small free concert in a garage so it just needs to be some what loud. Although I already found my speakers. Bought a set of JBL CF150's today for $100. They are going in my home system and then gonna be used for the concert.
Good job on the CF120s!
They should be absolutely killer at that concert.
I'm in the middle of buying some myself here's some specs
SPECIFICATIONS
First Manufactured 1995
Last Manufactured 1999
General
Recommended Power Amplifier Range 10 - 175 watts
Nominal Impedance 8 ohms
Woofer 12" High Polymer Laminate w/cast frame
Midrange Driver 4.5" High polymer Laminate
Tweeter 14mm titanium laminate
Frequency Response 36Hz - 20kHz
Crossover Frequency(ies) 800Hz - 7kHz
Sensitivity 96dB (1 watt/1 meter)
http://jbl.com/home/products/product_detail.aspx?prod=CF120BK&CheckProduct=Y
96 dB sensitivity!
100 watts should Bang! :yes:
Have a good time:banana:
Of that group, probably none would be good for what you are planning, and the JBLs are a much better choice. But the ADCs might be worth looking at -- not for loud noises, but for historical interest. They made some innovative and interesting speakers early on.
