On-Semi MJ21196, And you can't mix outputs..
Thanks. I'll replace all 5 outputs in both banks of the left channel.
What do you have for drivers?
HiThe service bulletin which was issued 10-81 concerning the "revision of model 700II and 400II from quasi-complimentary to full complimentary output stages" has some errors in the schematics. Including the D107 and D108 on the 700 II's and D108 and D109 on the 400 II's. These (1N4004) diodes do not exist on any fully complimentary 400 II or 700II amplifier I have ever seen including the PRO 700's and I have worked on quite a few of them. But then again one never really knows until they see every single fully comp 400II and 700II amp that Phase Linear ever made. So I could be proven wrong. The fully comp 700II's started with serial number 7A10701 around January 1981 and continued with the PRO700's.
I have also converted quite a few quasi-comp amps to fully comp. In the mid 1990's when I began converting amps over to a fully comp output I always had a fully comp amp sitting next to a quasi comp amp when I did the conversion to compare to. I have done it so many times now that I can do it from memory. I have told a number of people over the years that you shouldn't try converting an amp over to a fully comp output using these schematics alone or you might make some mistakes.
As to why these diodes were removed on the fully comp amps, I don't know why...I will have to ask Dean Nissen tomorrow. If he can't provide me with an answer perhaps Terry Pennington who did a lot of the design work on these amplifiers could.
By the way, there is a simple modification Dean showed me a few years ago that dramatically reduces the total harmonic distortion to levels as low as that of the 300 II. If my memory serves me correct it is in relocating C106 and C206. If you compare the Phase Linear 300II schematic with the 400II and 700II PL-36 pc board schematic you may be able to figure out where the capacitor locations are different. The (rare) PRO700 schematic I believe has this illustrated. The PRO 700 pc boards I have seen were drilled with an extra set of holes next to the 40412V1 transistor for relocating this capacitor.
Thank you Don,
Good to know! From the moment I once discovered a solid paper-clip instead of the right fuse can expect virtually anything in the socket… I guess in Europe ANSI fuse standards are not that common, which may lead owners to ‘unlimited fantasy’ sometimes.
Regards
Anyone have a service manual or schematic for a 4000 Series II preamp?
PL 700 II full complementary outpu repairs - cont.
Back to the project after 6-week break...
Current status:
- PL36 driver board works fine, all issues resolved - it allowed to put drivers in.
- Driver stage works fine
- All outputs in and final stage work fine – DC Offset readings around 2mV, the amp powered at the nominal PS voltage.
Still problems with signal flaw input->output – tracing in progress.
Some lessons for forum members as part of their own DIY repair projects are attached here in PDF – might be useful as rather not fully documented in PL700II service manual (many tx to THD+N!).
However the main issue for my amp, after stabilizing the driver board functioning, I think was a poor contact inside TO-3 sockets causing fault resistance for the power transistors leads.
PL36 wiring & marking - fully comp. output stage
I think, cracked it... It is apparently undocumented PCB version of PL36 designed for fully complementary output - have a look at the pictures attached (specially #3). There are two key points that seem to be different:
- factory embedded solution to cure possible oscillations at NPN/PNP predriver stage (cer.cap C->B)
- new wire: pre-driver C -> output common C.
Worth to mark it on the schematic - I leave it for a volunteer..
Inspection will be continued...
Cheers
ThanksThe caps are slow down caps from base to collector to stop oscillations. The driver board is the full comp (latest) version. Latest = 1981
