Seeing as my amp only has RCA inputs, is there any point in running an XLR to RCA cable vs RCA to RCA?
I also have some XLR to RCA connectors (home brew). I use these cables when I access feeds from mixing consoles. Sometimes those balanced feeds are too hot. An XLR/RCA adaptor drops that signal heat by 6dB, which makes it more friendly to some recorders that don't want the fully balanced hotter signal.
Hell yeah!
I run lots of configurations in recording. One of them is a means of converting a single XLR cable run into a single XLR cable as a stereo cable (Canare Star-Quad cable, L4E6S).
I built these custom cable ends to meet that need. They are specific to a particular preamp that I use that has a 3.5mm / 1/8" stereo putput jack (at least the connector wth the mini-TRS end)..
An XLR cable fits in between the connectors. It works perfectly, and has been used for up to a 50' run thus far.
The topic title is what my response was directed towards.
Ok, so my Gustard DAC-X12 has both balanced XLR and unbalanced RCA outputs. Seeing as my amp only has RCA inputs, is there any point in running an XLR to RCA cable vs RCA to RCA?
I suspect not though I'd like a confirmation if possible
I may just give it a try and see if there's an audible difference![]()
