How do you like the sound "as is" so far?
Scott
As is, they sound very good, even not placing the in the corner yet. I imagine the low end will come out better when placed there, but there's very adequate bass. They're a tad bright, especially when A-B'ing them with my Infinity Quantum 2s. I'm sure it's because of the tweeter. The hunt for original tweeters continues, these are definitely worth restoring.
The 4's are indeed a great little speaker. I've tried desperately for years to acquire a pair. Please don't mention the 901's. I've just had lunch.Well I've a set of vintage Allison 4's that I've had for quite sometime that I truly love. Using them as mains in my computer room system for a while. Amazing reproduction considering it's up-firing woofer and 901 like design.
Worf
They're missing the grills though. If someone has some close-ups of the grills, especially near the top between the mid and tweeter, I'd like to see them. I want to try to fabricate a pair of grills, but want to stay as close to the original design as possible.
The grills are fragile and I have plans of making grills for mine and cloth them with some Zilch Blue cloth long term.
The perforated grille material used on Allison loudspeaker systems is a formed plastic with high internal damping. We have found that this is the only grille format which can provide cover protection for the speakers mounted in the cabinet, yet does not attenuate high-frequency radiation at wide angles from the tweeter axes. This is an essential requirement for the Allison Tweeters which are omnidirectional in the front hemisphere.
The grilles will crack or break if they are deformed substantially. If you wish to paint them another color, however, they can be bent sufficiently to be removed from and reinserted in the cabinet. They simply snap into place in the recesses formed by the edges of the cabinet's vertical mounting panels.
It must be handled gently because it will break if bent too severely. If you do break a grille a replacement is available at $5.00 per panel.
I've got a set of those and several other Allison speakers. Love them. Mine have the grills. If you are ever on this side of the state you can stop by and see them.
