kydog
I am starting to put my first system together, and picked up an A-88x mostly because it was the cheapest thing I could find that had an input for a MM cartridge. Well it shows up last night, and everything looks great...then the problems start.
A friend had loaned me a pair of speaker cables with banana plugs so that I could listen, but I can not get the lug nuts out of the binding posts. I swear the plastic is one solid piece, and to further complicate things there is a little golden screen blocking my way in the center of the binding post.
Anyone have any suggestions? Or am I stuck with stripping some speaker wire and cramming them in the back of the binding posts?
As you unscrew the red/blk terminals there is a "Slot" exposed On the top of the binding posts to place the banana plug in each terminal. The "Lug nuts" are not fully removable
Place the plugs in and tighten by turning the "lugs" Very nice dual mono block amp btw...It's no slouch
You should do some research on the A88x..It part of the Pioneer Elite family...Not too many aroundAttachments
