aileenamegan
Its better to open a new thread for your KR-5010...
I didn't replace the switch but just cleaned it thoroughly and gently filed the contacts clean. The "fix" lasted about a month but the receiver started exhibiting signs of a failing switch again (flickering lights on power up).
I just went in and added a relay which will hopefully solve the problem for good. Also added some walnut side panels so it's looking and sounding great again.
musichal, just curious-- what gave you the impression this had a MOSFET amplifier in it?
View attachment 988444 View attachment 988446 View attachment 988448
I have the same receiver with the same issues, can you please give me help out and tell the walkthru on how one can add the relay. Thanks
I just by passed the sw. Or jumped it out andI got the idea of adding a relay from searching the forums. The flickering lights/arcing power switch is apparently a common problem on many makes of receivers (not just Kenwood) that use this type of power switch. Here's a post by Audiojones showing one of his relay installations: http://audiokarma.org/forums/showpost.php?p=5448354&postcount=11
The idea of the relay is to divert the high current power-on load off of the underengineered original power switch contacts to a more robust set of relay contacts. That way, every time you switch the receiver on, the original power switch only has to carry the relatively low current required by the relay coil.
I ended up finding this inexpensive SPDT relay at a local Grainger outlet (http://www.grainger.com/Grainger/OMRON-General-Purpose-Relay-4FE15?Pid=search). The specs looked similar to the RIBU1C that Audiojones shows so I thought I'd be ok using it. I was concerned about there still being an arc across the relay contacts so I added this MOV surge suppressor from RadioShack (http://www.radioshack.com/product/index.jsp?productId=2062574).
It took me awhile to trace the switch wiring and figure out exactly where to insert the relay. I sketched out how the existing power switch was wired relative to the power transformer and the back panel outlets and then I sketched out how the relay should be inserted. Once I did, the installation was pretty straight forward. I did have to lengthen one of the transformer leads a few inches but otherwise, I just had to add a couple of lengths of wiring to complete the installation. I found an empty spot on a small circuit board near the back panel to mechanically zip-tie down the relay. The relay is not electrically connected to that circuit board in any way.
Now when I switch on the power, I can hear the new relay clicking on firmly and the lights all come on cleanly and quickly. A few seconds later, the protection relay kicks in and all is well. I am no electronics guru so hopefully one of the real gurus on this forum will comment if they see anything stupid I did.
