I am planning to design a tube hifi amp in the future, I designed two tube guitar amps with power scaling and channel switching. This is a change to design a SS power amp.I design and build tube amps, but I tend to mix in a few transistors here and there.
Hey. that's very good, a lot better than just fixing and restoring. Most designs are quite standard. Even I design without referencing to any particular schematic, but basically it's a complementary IPS with current mirror load, EF VAS to increase the gain of the IPS stage. 3EF OPS stage to increase the gain of the VAS stage. It's the small little thing that improve from the basic design of the original schematic.I've built a number of tube amps, and plan to build more. But, they're more or less from existing designs with some deviations here and there.
I've also built a PassDIY B1. But, again, that's pretty much cookie cutter other than the case/enclosure.
Here are a couple of my designs with good published descriptions here on AK:What kind of tube amp you designed? SE or PP? I like to hear more.
My situation is similar, except that I had a career as an analog video circuit designer. I recently spent a chunk of my children's inheritance on test gear, including a new Tek 350MHz scope and a Stanford Research distortion analyzer, to gain maximum visibility into circuit behavior. I hope to gain a bit of notoriety as an unconventional tube amp designer before they carry my butt away!Electronics has always been my hobby. I retired and I am doing it as a hobby now. I have only myself to please, BUT I am taking it very serious.
The new scope is an MDO4034B-3. I bought it when Tek was closing out the older models and got a huge bundle of apps in the deal.You have the 2465A scope? That's what I have.
Isn't the two big round disc too heavy at 22lbs each?I like to repurpose stuff and sometimes an amp results. In my case, it would be based on available modules.
http://audiokarma.org/forums/index.php?threads/sony-str-v5-parts-to-live-again.649367/
This is now working, been my main amp for a few weeks. Still need to do some tweaks, but it sounds fine.
This guy is my new hero. Especially after issuing his VFET amp design kit over on diyaudio - buying the kit gets you genuine matched VFETs and tons of support, I doubt he's making much money by doing this, but a lot of kudos and respect. Plus its pretty great that he personally contributes regularly to the forums.Forget about making money, I question whether most of the successful designer like Nelson Pass making a lot of money
I ended up using a thinner disc for the top. I might build a second amp with the other thick one, since I have a transformer from a V6 and another pair of big heat sinks. I used a rectifier board module from the Bay, and a couple of LJM mosfet boards. I think they are called L150. LJM is a Chinese designer who has a pretty good reputation, although it's not real clear which supplier has the best implementation. I still need to test power output but the amp sounds good and is very quiet.
Can you give me a link to which VFET amp you referred to?
Do you have the schematic that you can post of the L150? I like to take a look. One thing, from the picture, it only has 2 pairs of output transistors. It would be nice to have like 4 or more pairs to lower the crossover distortion further.
