Anyone ever deal with this?
paulcalif
I bought a SX-770 to refurbish that has been a real challenge. Including modifying the main amp to use TIP41C's. Once I got that working great, I moved on to the FM section which didn't work at all, but this post is not about that receiver.
To help me figure out what was wrong with the 1st. 770's FM section, I bought a second one. It appeared untouched in original condition. The pots and switches needed to be cleaned. The knobs came of with the expected amount of force, but the switch covers were on really tight. I have restored 35 pioneer receivers this year, so I've pulled off a lot of switch covers. I use the spoon lever trick which has never failed me until yesterday. In the past, just a little more pressure always broke the switch covers loose. Not this time, I pressed hard, then harder, then real hard. Finally, it gave! But not the the cover, the shaft broke right out of the switch! Dammit, $35 lesson learned (replacement switch set).Turns out that someone epoxied the switch covers on!
I assumed the seller had no idea, but I did tell him. He didn't know but said that at house parties people would steal the switch covers and knobs off the stereo equipment and that gluing them on was fairly common. That was a first for me.
Any of you hifi veterans ever seen that before? It's kind of humorous really, I choose to laugh instead of cry
yeah. on a nikko nr819.
some one decided to epoxy on the balance knob for no reason that i could find
i do not and will not use spoons and even if i did use spoons, they could not have been used against the plexiglass on a nr719/819..... but it tore up my nylon pry tools pretty good.
i was starting to think that it was not coming off.
I've had the pot shaft pull out a few times, sometimes it's just weak or maybe the knob was glued on. Go figure.
I don't know why, but hearing that I'm not alone in this is comforting. I guess it's true that misery loves company
Update: I now have 6 of these SX-770's (think I have a problem lol). I'm also starting to think that the switch cover buttons were glued on at the factory, so that would make me the dummy for trying to remove them. They don't need to be removed as there is enough slack in the wires to pull the boards for access without removing the buttons. Live and learn.
