Ficklistnr
Passive Fanatic
I'll add a photo soon but Im hoping someone may have a little info on the company, products, specs and anything else relevant to a speaker brand name called "Eclipse"
I have seen them twice in my lifetime, once in 1989 when my father passed along a pair to me he was no longer interested in (which I sold or traded long ago) and today when a friend dropped off what appears to be the exact same thing.
They are 3 way active crossover floor standing speakers. The oak veneer cabinets are approximately 36 inches tall 14 inches wide and the depth at the base is 14 inches +/- From the base of the cabinet the face tapers back towards the top at about a 10 degree angle for an obvious upward firing design.
There is currently an 8 inch semi-transparent poly bass driver aligned in the middle of the cabinet. No Idea if it is OEM. Above center is an enclosed opening for what appears to be a 4.5 inch mid driver (not present) and one black "AUDAX POLYDAX HD 100 D 25" dome tweeter above it with round aluminum mounting plate. At the base is what I assume to be an opening for a 10 inch passive radiator as there are no signs of mounting hardware (brackets, screw holes etc. Nada!) The crossover appears to be configured to accommodate 3 voice coils @ 8 ohms impedance. The crossover components are glued to a piece of particle board and attached to the bottom of the cabinet. Obviously its an enclosed cabinet with no ports which makes sense with the opening that I assume used to contain a radiator.
Grills cover the entire face of the cabinet stopping 2 inches short of the base where a small strip of oak trim wraps the front.
These cabinets are very well built with furniture grade oak plywood sides and top, solid oak rounded corner trims at the top, and 5/8 particle board front and rear panels.
I remember nothing about the pair my father gave me other than the fact that I was very impressed with their design, sound and furniture grade cabinets. I believe my father told me he purchased them from a small privately owned specialty audio retailer in Portland Oregon. I do recall seeing the same design and badge years later at a Radio Shack in Portland and I believe one of the staff had mentioned that Radio Shack had purchased the Eclipse name.
My first interest is OEM replacement drivers/tweeters and where to find them. (Radio Shack says "nay")
I'd be very interested in component specs assuming OEM parts will be extremely hard to find if anyone could help me out in that realm.
Thanks
Pics to follow within a day or so.
Thanks
