Anyone know about ham radio gear?
Bigerik
AK Subscriber
Clearing out some of my dads old gear, and am not sure what to do with his old ham radio gear. He has a Yaesu FT-107M ham radio with separate, matching power supply.
Anyone familiar with this set? Is it still usable or desirable?
Thanks!
i would say its usable and desirable take a look on ebay just enter Yaesu FT . i have a comms receiver on there its getting lots of interest .i reckon a 2 way will get lots more ..
Thanks!
It is both. If it has all the add on boards and filters even more. I still can't afford one. :drool:
Check online for Ham radio clubs in your area. There's probably someone local who can look over what you have and maybe even take it off your hands for a fair price.
But at the same time, why not consider using it yourself. Your Dad would be proud and it ight be a great start to a rewarding hobby! :thmbsp:
yep try it out no harm listening in but you may need ham licence to transmit ..you do over here ..prob gets 26-27mhz you could use that to transmit as its cb band
It would be cool to use the Yaesu but there is a bit of involvement like licensing, towers, and other setup issues. The guys on Videokarma could probably answer all your questions.
It's an 80's vintage HF rig. A few generations behind the latest and greatest but still quite usable. It does require an amateur radio license to use on the air but you could connect it to a 50 Ohm 200 watt dummy load for testing.
Features
• 160-10 Meters
• Solid State
• VOX
• Peak/Notch Filter
• Noise Blanker • 240 Watts Input
• Semi Break-in CW
• Variable IF Bandwidth
• Speech Processor
The Yaesu FT-107M is a solid-state HF transceiver covering 160 to 10 meters in SSB, CW, AM and FSK modes. There is also WWV/JJY receive at 5 MHz. Power input is 240 watts on SSB/CW and 80 watts on AM/FSK. It features a digital display and an analog subdial. The supplied SSB filter is 2.4 kHz. The FT-107M requires 13.8 VDC at 20 amps. This radio does not have general coverage receive. It is supplied with a DC cable.
Here's a video of a working unit: http://youtu.be/cAqW2dzlUkI
Here is a link showing how to enable the WARC bands (30m, 17m and 12m) by removing three diodes.
http://www.jorgje.net/index.php?opt...fix20090216&catid=8:categoryhamradio&Itemid=9
Very nice radio in the lineup. All of my current radios are Yaesu. The FT-107M should be worth good money. Go to eHam.net and read the reviews on it to get an idea. Maybe you can find a ham radio operator locally that can test it out for you.
With all due respects, you might want to listen in on a few ham radio conversations before investing a lot of money - just to make sure it's to your liking.
My experience has been that it's a lot like CB with a smattering of manners.
You can get a HAM licence now with knowing code. That was the part that always tripped me up.
Yup. You would need at least a General Class license to get full use out of that rig, and it's pretty easy. Some basic tech questions, rules & regs, etc.
IIRC, www.qrz.com has a link to sample tests. Start with the Technican Class & see how ya do...then give the General a shot. Sample questions are all taken from the current test question pool, so you're not messing with outdated info. If there's a ham club in your area, they periodically offer testing. $14 gets you your ticket. Dunno if that radio has a built-in antenna tuner...so, depending upon the antenna used, one of those may be a good investment. (used tuners run $50-$150) A simple dipole like a G5RV would get ya on the air, or, if space is limited, a vertical can be effective. There's even "apartment" verticals designed to be clamped to a balcony railing.
Even an SWL (Short Wave Listener) might like it - I haven't listened for ages with anything decent, so don't know if many radio amateurs (Hams :sigh: ) are still 'out-there'
Sell or give don't bin :thmbsp:
G'day all, yes the FT107M is a good HF transceiver. I don't think too many made it to Australia, but a friend of mine locally had one and I thought it was quite good with numerous operational refinements.
I remember it to be all 'solid state' (transistor) circuitry and I thought it sounded pretty good 'on air' as well. Regards, Felix (vk4fuq) aka catman.
Hey, Bigerik...one additional question: Like many of us here on AK, hams can sometimes be "accumulators". Any other goodies of your Dad's that may be interesting?
