Hard to beli:ve that the Pickering XV-15 has been around since 1968:
http://www.alliedcatalogs.com/html/1968-270/h058.html
The new nude elliptical EVG PM4000DE should be a nice upgrade for the Pickering V-15 and Stanton 500.
Time will tell on that. For me, must be as rugged as original, track at the same forces original does, and track what the original does. Must last as long as original, or be seriously cheaper. Must also be consistent like originals were when made in Plainview, NY. Plan on getting some to try.
I worked at Pickering/Stanton in Plainview, NY (Long Island) from 1971-1973. John Kuehn was my boss (Chief Engineer). Much of my work was related to the CD4 4-channel cartridges (XV-15/1200E). CD4 was based on high and base bands. The high band went to 40KHz. Getting a mechanical stylus to vibrate that fast with a flat response was quite difficult. The CD4 project was Walter Stanton's baby and he hovered over me every day waiting for results. In those days all cartridge design was based on progress testing. Build something, test it, make a change and test again. Walter always told me "Only change one thing at a time." I heard that 10+ times a day.View attachment 2166191 I worked at Pickering/Stanton in Plainview, NY (Long Island) from 1971-1973. John Kuehn was my boss (Chief Engineer). Much of my work was related to the CD4 4-channel cartridges (XV-15/1200E). CD4 was based on high and base bands. The high band went to 40KHz. Getting a mechanical stylus to vibrate that fast with a flat response was quite difficult. The CD4 project was Walter Stanton's baby and he hovered over me every day waiting for results. In those days all cartridge design was based on progress testing. Build something, test it, make a change and test again. Walter always told me "Only change one thing at a time." I heard that 10+ times a day.
I still have one of the XV-15/1200E CD4 cartridges and 2 of the test records that we used. After frequency response testing successful cartridges were audibly tested with these records with 4 of the electrostatic speakers in each corner of the listening room. We must have played the same 1 or 2 cuts 100's of times. The cartridge in the original box is in the center of the attached photo sitting in our curio cabinet.
The Pickering and Stanton cartridges were built on the same production lines and were very similar in design. The higher quality cartridges were built in Plainview and the lower end in Freeport, NY (about 14 miles away). We also marketed a dynamic headphone and turntable. We did engineering samples of electrostatic speakers and headphones. I still have one of the electrostatic headphones. It operated around 3000V and I am afraid to try it after all those years - the insulation may have broken down.
Very nice to have you on the site and really appreciate the historical input.
I’m certainly a big fan of Pickering & Stanton products.....
VR
Andy
I’ve seen stylii labeled as D81 and D81S as well.BTW does anyone know what the difference between the D81 and D80 stylus are?
If you look carefully you will see that the numbering goes from 0 - 10. It isn't a clock - it's an aircraft altimeter from a 1943 Beechcraft Staggerwing. I owned it for many years and was in the process of restoring it. A total restoration takes 8000+ hours which was too much for me to do myself so I sold the project last October.Btw, What is the clock?
Aha!If you look carefully you will see that the numbering goes from 0 - 10. It isn't a clock - it's an aircraft altimeter from a 1943 Beechcraft Staggerwing. I owned it for many years and was in the process of restoring it. A total restoration takes 8000+ hours which was too much for me to do myself so I sold the project last October.
Best to replace it. the damper is probably shot. When I was there all the dampers (donut-shaped material that supported the stylus in the housing) were all rubber. We had just started experimenting with synthetic materials, which at the time, varied from lot-to-lot.Interesting thread,,, I recently(last weekend) researched Pickering/Stanton, as I just came across a Pickering P/AC-1 cartridge I had for years... I never played it as I never found a stylus... Seems its a forerunner of the Stanton 500 series, and any of those nails would work... There appears to be a lot of replacements available, so I'm still a bit confused as to which one would be a good choice to finally try this cartridge...
What fun is that? Most of my cartridges are vintage,,, Shure and Empire mostly... they seem to respond well to new stylus... I think I can borrow a stylus from a buddy and try out...Best to replace it.
How do you prevent the stylus from twisting in the body,, glue?
