Anyone use the Oppo app ?
Kgveteran
Hey all, i have an Oppo 103, i just found the Oppo app and loaded it on my iphone, cool. It recognizes my iphone of course and Tidal appears.
how do i get pandora on the app so i can disconnect my monitor and just use my oppo app for pandora
pandora is available if i use a monitor
The only Oppo app I can find on the Play Store is Oppo Sonica, which doesn't seem to be relevant to players. And only has 50k downloads.
So, no, maybe no one here uses the Oppo app...
Or maybe you need to wait until people have woken up...
Wait….. no one here uses the Oppo app ?
The app is good for Tidal and music from your own network.
Pandora should be on the main menu screen when you turn your Oppo on.
That’s the way it is with my Oppo 105D.
Also, the app sucks. Sometimes freezes, sometimes works perfect. Sometimes won’t recognize my phone or tablet.
There’s no updates to fix anything either.
I actually deleted it and re-installed it one time and that helped some.
I wish you well.
The app shows up when I checked on my IPhone. 1st app listed.
I did a few searches last night after the OP asked. I'm fairly certain it is only available for iPhone, not android.
I've got the Oppo Media App on my iPhone - frankly, I never used it!
Just went into Setup - it found our 103D downstairs in the media room (on my network); and also shows:
my MacPro here in the (home) office; Logitech Media Server (the Raspberry Pi); DVD Video (last night's movie, still in the machine) ; and TIDAL; which I don't have a live account for. Sadly, it doesn't show Qobuz - tho it might have if Oppo had stayed in the business.
I don't use the Oppo app either (I'm on android). But hjames info above is interesting.
Kgveteran, as I said in your other thread, there are numerous ways to stream Pandora to your system and eliminate the need for the Sonos. (Which I believe is your end goal.)
I just did it myself to ensure everything worked smoothly (as I don't use Pandora). It took maybe 3 minutes to have Pandora up on my Node, connected with bluetooth. Phone is bluetooth source, Node is bluetooth receiver. Done.
(Is this what you are looking for?)
Wondering, since Oppo service is still around, if they couldn’t do an update for the app to make it work with Qobuz. Doesn’t seem like a big issue for the technically savvy.
Oh, gotcha, i found my Node on Bluetooth settings. I gave it a listen and i think i’ll keep my SonosPort in the system connected to my Parasounds dig coax, i really like the D/A in the Hint6. Which is weird cause i think the Node uses the same Sabre…..
Thank you very much, i didn’t understand before how i could connect using my iphone, my misunderstanding totally
