shacky
Addicted Member
I have a set of early 2AX's. Woofers have the treated cloth surrounds. When I was bringing these back to life a few months ago followed some AK advice and used Rubber Cement to re-seal the surrounds - to make sure they are air tight as designed.
My speakers sound very good, however, I noted the "push test" in other threads and decided to see how air tight my cabs really are. My woofers come out 90% pretty quickly so I think the air seal could be better.
But... Ialso noticed that when I push my woofers in the cloth surround seems to distort - almost crinkle in areas. I'm thinking this may not be good. Shoul I consider replacing surrounds? And if so what kind of surround material? I'm thinking these old cones were designed for use with original cloth which I would think is more compliant that rubber/foam surrounds.
Any advice will be appreciated. Hoping someone says the crinkling of the cloth surrounds is no big deal. I'm concerned that it may put undo strain on voice coil alignment.
