AR-3a Question
Faintstar
Hello all, this is my first post.
I picked these possible AR3(a)s recently and when I popped the grills off, I found a roughly 10-inch woofer with only 4 screws, so I'm fairly certain these are not original, but then again, I don't see any old holes. I was curious if these are simply cheap replacements as I haven't seen any images of other AR-3(a) speakers with these same woofers, any input would be appreciated.
I picked these possible AR3(a)s recently and when I popped the grills off, I found a roughly 10-inch woofer with only 4 screws, .... I was curious if these are simply cheap replacements
I can't comment on if they were cheap or not but definitely looks to be a replacement.
Sit tight as I'm sure some of the more AR knowledgeable will stop by and offer their assement.
Welcome to AK!!!
Those look like AR woofers. Since they're a 10" woofer, they may have been from AR-5s. Regardless, the AR 12" woofer has a truncated frame, which makes the 12" driver easily identifiable.
ACOUSTIC_RESEARCH_AR_3a_AR3a_Woofer_Speaker_Alnico_Original_Works_Needs_Refoam_01_vri.jpg
I believe you are correct @homebrew, thanks for the correction, I believe they are AR-5's I didn't know what I was getting but I got them for next to nothing so I figured I'd take the chance.
This is all good information, I’m hoping they’re original. I had no idea what they were as the badges were missing and only one had the paperwork stapled to the back. Looking forward to bringing them back to life.
What is your level of expertise with regards to speaker repair?
I ask because the woofers will obviously need to be refoamed which in the hands of a novice can be a tricky thing.
You'll want to replace the 50+ years old capacitors and more the likely the pots will need to be assessed too.
I haven't repaired any speakers before, yet I have re-capped and refurbished my slightly later period Pioneer 980 receiver.
This will be my first go at speaker restoration. It seems I should test and verify all the electronics, replace the original Pots with L-Pads (this appears to be the go-to consensus) 3 of my pots are scratchy and one of them is wobbly and loose, so, although I'd rather simply swap them out instead of cleaning them up.
AR 5's are almost everything AR3a's are, but remember they are 8 ohm speakers so AR3a tweeters and midranges wont work. Go over to Classic Speaker Pages and read the AR3a restoration guide, a lot of good information in there that will apply to your AR5's. Good Luck
L-pads was (were?) a go-to when there weren't suitable pot replacements.
search "acoustic research potentiometers" on ebay
The Ohmite on the left are real expensive. The white ceramic Potentiometers are a perfect match and much more affordable. I highly recommend these.
