AR-90 vs. AR-91/92
crunkarelli
How much better are AR-90s vs. AR-91s or 92s.
I'm sure the bass is bigger but all three share the same mids and tweets, so I presume the rest of the sound is quite similar. For instance, would the AR-92 sound pretty much the same as the 90 if it were paired with a sub to provide more bass?
I'm looking at both the 90 and the 92 (once I get my amplification figured out since they're both power hogs). The 90s are 3x more expensive than the 92 since they are indeed higher end, more collectible, veneer vs. vinyl etc. If the 90s blow them away then perhaps it's worth it. If not, I could pocket the change or get the 92s plus a pair of 3-way ADS and get a two-for-one deal!
Thoughts?
What are the 3-way aDs?
And yes a sub would help the smaller ARs out, but then you're back to adding the cost of subs and sub amps, plus most likely running the signal through the sub amp's bypass filter, which I find compromises sound.
ADS L-630 + AR-92 are still cheaper than AR-90s.
So on the Arnold vs. Arnold analogy, is that strictly from a bass standpoint?
The 9/90 is a very impressive speaker and just has a full and powerful sound to them that's head and shoulders a I've the others.
Sure, you can add a sub to them. But the 9/90 has a synergy right out of the box that will take lots of work to duplicate.
The aDs L630s are a fantastic aDs speaker and would give you severe bang for buck. I would either choose the L630s and pass on the smaller ARs or go whole hog for the ARs.
Ps- the 630s are much less demanding.
Go listen to the L630s and see if the bass is good for you. If not, I'd aim high and go for the 9/90s and proper amp power to run 'em.
