AR Rega
hjfischer
Attached is a pic of my AR turntable with a Rega arm salvaged from a Planar table. I need some suggestions on which cartridge would be a good fit for the arm. My budget won't make past US $200. (If anyone is curious as to why the arm has no lift, I'll gladly answer but that's another story!) Thanks.
The arm was removed by a previous owner from an apparently damaged housing for the lift. However this left a 1/4" gap in the mounting base. I determined that the bearings were unaffected and that the arm functioned smoothly. I mounted it on a new arm board with the correct effective length, taped over the gap and fashioned a wood support for the arm. It seems to be OK and I want to get an appropriate cartridge for it.
I love the Denon DL-160 on my AR ES-1 with a Sumiko MMT arm and your rega is supposed to be nicer than it so I would think that would be a great fit for an MC cart!
