Jesse Garron said:
Hi All - quick update...
They can restore the attenuators, but it sounds like most folks here are just bypassing them - correct?
Jesse, like ozmoid said, you have a few options. I would NOT by-pass the mid pot (I did that for a while and am no longer). Problem is really with the AR-3a tweeter. Of all of the drivers in the 3a, the tweeter is really marginal by modern standards. By comparison, the mid-driver and woofer are simply outstanding drivers even 40 years later!
Problem with the tweeter is the volume of it's output. Here you really do want to by-pass the tweeter pot COMPLETELY. You do this to get as much sound as you can out of the tweeter.
For the mid-driver, I would by-pass the WIPER. That is, solder the lead going to the wiper to the top of the pot. This is the same as setting the mid-pot to it's maximum position 40 years ago before corrosion set in.
Ozmoid, is correct in that these changes can make the speakers a little more forward especially, if you raise the speakers off the floor. Raising the speakers (with speaker stands etc.) diminishes the deep bass reinforcement you get by having the 3a's on the floor. So, when you effectively "cut the bass", the speakers will sound a little harsh or forward. (Please remember that the 3a will produce significantly MORE bass and deeper bass than the 2ax's that ozmoid has. Many reviewers over the years have characterized 3a's as "bass heavy" speakers, so a little boost in the mids and highs is usually appreciated.)
Jesse, if you leave the speakers on the floor, however, the balance with the pots as I described should be just about perfect PLUS ... you'll now hear that terrific DEEP, undistorted bass that made AR famous.
Regards,
Jerry
PS: ozmoid is also correct that if you want to push these speakers to their maximum potential, horizontal passive bi-amping will allow you to get everything out of them.
Below are the details for the pot mod. Even with this mod my 3a's are NOT as bright as my more modern pair of AR's with a 12 inch acoustic suspension woofer:
