I believe the AR5 and the LST tweeter are the same. The midrange fits the LST AR-3a and the AR-11.
Lots of confusion on this issue. To make matters worse, each individual driver went through a variety of changes over the course of its lifetime. Let me see if I can set this straight. Generally speaking:
The big phenolic dome tweeter is from either the AR-3 or an early AR-2a or AR-2ax. Despite the fact that the AR-3 is a 4 ohm system and the 2-series were 8 ohm, there is only one 4 ohm version of this driver.
The later 4 ohm paper dome tweeter was used in the AR-3a and AR-LST. Adding confusion, it was also used on the very last of the AR-3 to leave the production line and was used as a service replacement for the AR-3 tweeter.
The 8 ohm paper dome tweeter was used in the AR-5, AR-LST2, and later AR-2ax and AR-2a. THIS IS THE ONE THE OP IS LOOKING FOR FOR HIS LST2.
There were two different 4 ohm cloth dome tweeters (the later version used ferrofluid) used in the AR-11 and AR-10pi. Just to confuse the issue further, this style of tweeter (if not, in later years, the same model number) was the service replacement for the AR-3a and AR-LST from 1976 until the early 90s. Some of the last of the AR-3a may have been equipped with this tweeter from the factory and many wound up being used in AR-3a and AR-LST as service replacements. The most recent version of this tweeter was used in the AR-3a Limited in 1991.
All clear?
Since somebody brought up midranges:
There's the 4 ohm one from the AR-3. Because the 4 ohm paper dome tweeter was used at the end of the AR-3 run, the cloth surround woofer was used in the early AR-3a (just as the foam surround woofer was used in later AR-3) and at some point the AR-3 migrated to the later cabinet style, this midrange is the only reliable distinguishing feature of the AR-3.
There's the different 4 ohm midrange in the AR-3a and AR-LST.
There's the 8 ohm one (visually identical to the 3a midrange) in the AR-5 and AR-LST2.
There's a different 4 ohm one yet in the AR-11 and AR-10pi. Like the AR-11 tweeter, it may have been used in the 3a at the end of its run, and was used as a service replacement for the 3a and LST.
