pjsjr
Playing Around
Last night I attempted to "fix" the damping on my XA TT...I could not get the two screws(cone pivot bearings) loose to do the work:scratch2:.
I need some suggestions,tried different screwdivers and pressure, also heated up the screw with a soldering iron(maybe not hot enough???). TIA, Preston
This is from Audio Basic via Vinyl Nirvana AR mods...“back off” the
two cone pivot bearings on each side of the
outer casting until the chrome cylinder and
inner brass cylinder can be removed.
