DijonMaster
I've been trying to fix up my thrifted Acoustic Research XA. The motor seems to have a loud buzz/grind to it, but only when it's low in the shaft. If I pick up the motor spindle a bit or put a piece of felt to separate it from the plinth, the noise quiets down significantly.
The noise gets worse when I add the pulley. The pulley also seems like it's shaking slightly, causing the noise.
Any advice? I oiled the motor
