AR XA MOTOR RUBBER GASKET
sferlazz
Good morning Gentlemen,
while i was giving a renew to my AR XA the rubber gasket that fits around the spindle got out (i think it had more than 40 years...). It seems to keep steady the rotation so now the motor goes up and down. It's about 0.5 mm diameter. Does someone has an advice where i can find a new one and i can i put it back, the space is very narrow?
I believe that to be an odd, and rare version of the haydon motor. that was a snap ring that was in there...........have no idea where one can be found
Thank you very much, i am honored to recie ve an answer from you, i've red your name in many forums on AR turntables.
I hope you are doing fine.
It's right it is an haydon motor. If i find anything alike, do you think it's possible to put it in?
