StuartB
My suggestion - while you have it apart change the arm tube from the stock AR tube to a Technics arm tube. The collar and solder points are easier to work on. You can upgrade the wire to something equally good, but easier to work with. You can then use any standard SME style headshell, and you will have more flexibility in aligning your cartridge with most headshells. Several of us can offer more into if desired.
