Hey, I have seen alot of turntable design where they appear to have a platter system which resembles essentially the AR XA without the outer platter. Can you run an AR XA like this? I was thinking if you used a a record weight which as as heavy as the outer platter, it would balance the suspension fine and hold the record flat. What would be the advantage? None, except for I now have an XA without an outer platter, counterweight, and headshell. Just exploring alternatives. Would this work?
