I have an AR XB turntable that is not cueing with the cue lever. I have checked the cueing cylinder, cleaned, and added 100,000 silicone grease to the well. The post that presses up against the tone arm raises and lowers but does not contact the tone arm no matter how I adjust it..
On another thread about the AR XB I saw something about a .219 ball bearing in the bottom of the cueing cylinder. Mine has no ball bearing. Is this is the cause of my problem, if so, where can I get the proper ball bearing?
I also saw something somewhere about adjusting the travel of the cable that is activated by the cueing lever to increase or decrease the amount of "push" on the cueing piston. To do this the bottom cover needs to come off. It seems AR didn't see the need for removing the bottom cover as they didn't make it easy to do. It appears I have to pull four staples from the bottom cover to get at the internals above it, yes, no?
If AR didn't see the need to make the internals easily accessible from the bottom it would follow that there wouldn't be much if any maintenance on this table that would be necessary from the bottom and I should remove the bottom only as a last resort?
