andhol
Hello everyone and thanks for the help in advance
I've recently acquired a beautiful XB in original condition ( I think ) with the dust cover.
It sort of works and keeps good speed at 33.33rpm but it has some quirks:
1. The motor is noisy (it is the original Haydon). I've tried the method of dropping oil into the motor, which helps muting the sound but there is still a faint but audible 'tktktk' sound, which worsens with use. The rod sticking up from the motor has minimal play both vertically and horizontally.
Should I open the motor up and flush it, or is cleaning it not an option anymore?
2. The sub-chassis is sloshing around, which is worsened by a slightly bent spindle (I think). When I'm playing a record the platter and tonearm are both shaking, sometimes it's a bit better, sometimes it's quite bad; maybe time for new springs even though there doesn't seem to be much slack on the chassis?
3. Who makes good belts for these? The one right now seems fairly used, which probably worsens the problems with the table..
4. The cueing is extremely sticky, probably in need of a good cleaning: what oil should be used for it?
Now I know there are probably answers somewhere here in the AK forum, but I'm planning on modding this table (with your help
) so I figured a dedicated thread would be nice for this table.
Attached are some pictures of the table!
Greetings from Finland, I probably own one of the only AR tables over here
EDIT: forgot to mention that I've cleaned the platter well with IPA and filled it with oil, cleaned the subplatter and the spindle also, the 'putty' modification for added weight has also been done (not by me)
