Maybe not breaking news but I thought a quick AR2a refurb story wouldn't hurt.
Victims are a pair of AR2a in utility cabinet pine ply that are stained a walnut hue. These are the type with 1 3/8" hard phenolic dome tweets like the AR3 and the 2 x 5" fiberglass stuffed cone mids in the plastic hog trough. I vaguely remember plugging them in at the time they were acquired long ago, finding there was NO top end and sticking them in the pile of "retirement projects" without really doing any research.
I didn't remember that they were "a" models so, thinking they were just AR2 without a real tweeter, I kept a look out for some high frequency help like the Microstatic tweeter array, MS-1. As luck would have it I just recently pulled the trigger on a set right before I dug these old dogs out from WAY back in the pile. SURPRISE! Being "a" models, they should already have all the help they need up there. Problem was still no sound from mids nor tweet. I guess they hadn't healed up, even with the 25 year rest!
These speakers were actually in very good shape compared to many I've seen pics of. They never had the grilles removed and it looks like nobody ever tried. After removing all the staples (except one!) I used the paint can opener approach and popped the first one open to inspect:
I followed some recommendations on AK and elsewhere about pulling the woof. Scraped out and saved the caulking squeeze out from around the aluminum frame then used an oversized machine screw and wedged it in one of the mounting holes. This provides a point where one can get some leverage with a small Wonder Bar (or claw hammer I suppose) and lift the frame out without boogering up the cabinet or driver.
Made a quick drawing of the crossover stuff and disconnected enough wires to measure caps, drivers and inductor.
4uF = 5.2uF (replaced with 4.1uF)
6uF = 7.9uF (replaced with 6.4uF)
L1 = 1.25mH
Pots = 16ohm wire wound
Woofer = 6ohms DCR
Mids = 1.7ohms DCR (both drivers in parallel)
Tweet = 2.1ohms DCR
The caps hadn't drifted as badly as I would have thought but they were far out enough that I replaced them with the old standby Dayton 5% Poly Film units cause I had 'em.
Pulled the wire wound pots and found the typical condition where the wiper wasn't making contact due to corrosion. THIS be why no tweety sounds was happenin'! The nice thing is that these old pots were MADE to be maintained with a convenient wire bail to hold the body together. What America Used To Was. Go Figure. A Dremel wire brush combined with some crocus cloth and a DeOxit bath followed by some dielectric grease as a SWAG to delay future corrosion and it's back among the living. Like many others, I think it would probably be a good idea to find a preferred setting for the pots and simply make a fixed resistor network to replace each of them, but not right now ...
Buttoned stuff back up and DANG! Everything works! On this one at least. The woof surround even seems to hold air. This speaker sure sounds nice. Nothing earth shattering but I imagine at the time they were made (old wax block cap had date of 1964, 62 years!) they were probably right up there in terms of "HiFi". Not too shabby nowadays either ...
Tomorrow, AR2a #2!
L1 = 1.25mH
Woofer = 6ohms DCR
Tweet = 2.1ohms DCR
Tomorrow, AR2a #2!
