Couldbfishin
Couldbfishin
Hello,I have a pair of British AR2ax speakers that have been run with a Bang and Olufsen BeoSystem 5500, about the same vintage, and they sounded great. I decided to disconnect them and move them to the MBR. All I did was unplug the B&O adapters from their sockets on the back of the B&O receiver, and disconnect the speaker wire from the backs of the AR2ax speakers. I set it back up in the other room, and then turned the receiver and CD player on. The music was VERY distorted and sounded terrible. So I quickly turned the amp off.
I found on the net some wiring instructions for the AR2ax. It said:
Terminal 1 is for the woofer and the negative or common speaker wire should be connected to it.
Terminal 2 is for the mid-range and the positive speaker wire should be connected to it.
Terminal 3 is for the tweeter and should be bi-wired to Terminal 2 if not intended to be powered separately.
My speaker has been bi-wired between terminals 2 and 3 since I bought them years ago, and it always sounded great, until today.
I double checked my connections and sure enough I had the + and - backwards. I corrected the wiring and turned the receiver back on, with a CD. The sound is still awful. Just like before I reversed the speaker wires.
What have I done wrong? Have I damaged something on the receiver, on the speakers? Any ideas?
See photos below.
Thanks.
