elitopus
Addicted Member
So I ended up with this trio of AR4x (thank you @bowtie427ss)
Two have the papers still on the back, and the third doesn’t. The two with the papers are S/N
FX176846
FX176843
I took the orphan apart first, cleaned the pot, and it’s operational now. I did not recap it. The pair I will recap.
The first to be opened up is S/N FX176843. It has date codes on the tweeter of 7/23/68, and on the woofer 5/2/68.
Check out that cad powder. Yum
This one has a 20uf cap, and a -4 coil. I thought they usually came with a -5 except for the oddballs, but whatever.
My first question is the edge of the tweeter is pulling off from the metal frame on both speakers. Can I just glue these back with some Aleenes?
Second, the pot is pretty crusty in the first one I opened. Even after cleaning it it doesn’t make a good full sweep. In my drawer of parts I found these two metal shaft pots that I think came out of some earlier AR4x (at one point I had AR4, AR4x, AR4ax, and multiple parts speakers). Maybe they even came out of some AR4? IDK.
Anyways, the plan is to use those. One looks brand new inside, and the other looks pretty nice.
The new looking one goes from .1 ohms, all the way to 15.1 ohms over its operating range. The other one goes from .7 to 14.9 ohms. So not bad.
One woofer has a little tear in it that I’ll patch up from the back with Aleenes.
Also, when I measured the 20uf cap in the first speaker, it measures over 39uf. When I measure the new caps going into the speaker and it reads 20.2uf, so I don’t think it’s an LCR error. I’ll measure the other speaker and see what it is.
I’ll take some of the exterior soon. They’re in pretty good shape.
I think I’ll put some new wire inside. The old wires are always so short. Another 6” would help out a lot.
FX176846
FX176843
