pjstone
Member
I have a 4004 mkii that the right channel produces no sound. This is what I have observed. The relay looks terrible through the plastic. I havent tried to take it out or open it.
I have biased and set dc offset which is pretty much spot on at +-2mv dc offset and bias at 9.9. I see no burned parts fuses are good rails are 70v.
I have measured a high esr on the right channel driver board of 5 or 6 ohms on one of the orange 1000uf 16v caps. Not sure if that would cause the issue.
I have not tried to bypass the relay on the right channel to see if i get sound. I have noticed that if i tap the case sometimes the left channel will go out and a tap will make it come back.
I have ordered a new relay from mouser or digikey cant remember which right now. What do you think? Am i on the right road?
Thank you so much
Phil
Thank you so much
Phil
