ZeroG
This Arcam DV88 was seldom used when acquired as used about 8 years ago, but intended for use as an excellent CD and DVD-A player. When I last operated it, the tray belt was rotted, so I changed it out for a fresh belt, a task I have performed maybe a dozen times on CD and DVD players. This transport uses the small belt like a computer drive and it's not even close to the laser. When testing the unit after repair, I discovered the cd would not always track properly, and there were random pops and noises along with an occasional whooshing noise. I ran my CD cleaner disk with no improvement, and thought the laser might be bad.
Finally I inserted a DVD-Audio disk which played perfectly. I'm presuming that means the transport / laser is good (only one laser) and guessing that it's a circuit problem somewhere? There are also quite a few thin wires that may possible have gotten loose or pinched when the cover was slid off but I don't recall any snags while opening it up.
Hopeful that someone here has successfully dealt with similar problems. Anyone have a clue what's causing this or how best to troubleshoot? It's a pan style box so no bottom access panel. Thanks for all replies!
