xchg.ca
Hi guys, this is a list of transistor I have in HK CD-401 deck
It suffers from low record/playback level
I have found and replaced leaked caps ( 10mFx16V and 1mFx50V )
I also found that 2x2SC2878(B) in rec-mute circuit were partially opened all the time regardless of button ( at the moment they just removed )
Here is the list of all transistors of the deck. I did search and cross reference with a list posted in forums. Seems like there are no know bad ones on my list! But may be I've missed some?
HK CD 401 list of transistors
Main Board
2SB855(C)
2SC2603(F) X3
2SA1115(F)
2SC1419(C)
2SD2236(Y)
2SA1115(F) OR 2SA1115(E) X10
2SC2603(F) OR 2SC2603(E) X35
2SC2320L(F) X4
2SD667(C)
2SA999L(F)
2SK163(M)
2SB647(C)
2SC2878(B) X2
LINE AMP, MIC BOARD
2SC2320L(F) X2
2SA999L(F) X2
FET - 2SK170(GR) X2
FET - 2SJ74(GR) X2
2SA984(F) X2
2SC2274(F) X2
2SC2603(F) OR 2SC2603(E) X2
2SC2603(F)
2SC2320(D) OR 2SC2320(E) X2
2SC2878(B) X2
Logic Control board
2SC2236(Y) X3
2SA1115(E) OR 2SA1115(F) X5
2SC2603(E) OR 2SC2603(F) X7
HX PRO BOARD
2SD667(C) X2
PB EQUALIZER
2SA1190(E) OR 2SA1190(D) X2
2SC2855(E) OR 2SC2855(D) X2
2SC2320L(F) X2
2SA999(F) X2
ELECTRONIC COUNTER BOARD
TORQUE CONTROL BOARD
2SC2320(F) OR 2SC2320(E)
Main Board
2SB855(C)
2SC2603(F) X3
2SA1115(F)
2SC1419(C)
2SD2236(Y)
2SC2320L(F) X4
2SD667(C)
2SA999L(F)
2SK163(M)
2SB647(C)
2SC2878(B) X2
LINE AMP, MIC BOARD
2SC2320L(F) X2
2SA999L(F) X2
FET - 2SK170(GR) X2
FET - 2SJ74(GR) X2
2SA984(F) X2
2SC2274(F) X2
2SC2603(F)
2SC2878(B) X2
Logic Control board
2SC2236(Y) X3
HX PRO BOARD
2SD667(C) X2
PB EQUALIZER
2SC2320L(F) X2
2SA999(F) X2
